Peace80
4 Şub 2017
Sevgili Arkadaşlar,
Sıfır aldığım ve kısa süre (6 ay) kullandığım Helix P TWO amfi satılıktır. Sıfır diye satılabilir. İğne ucu çizik dahi yok.
Fiyat 500 EUR.
Saygılar
Technical data​
Output power RMS ≤ 1% THD+N
- @ 4 Ohms2 x 280 Watts
- @ 2 Ohms2 x 490 Watts
- @ 1 Ohm-
- bridged @ 4 Ohms-
- bridged @ 2 Ohms-
Max. output power per channel*Up to 600 Watts RMS @ 2 Ohms
Amplifier technologyUltra HD Class D
Inputs2 x RCA / Cinch
2 x Highlevel speaker input
1 x Optical SPDIF (28 - 96 kHz)
1 x Remote In
1 x Remote control input
Input sensitivityRCA / Cinch 2 - 8 Volts
Highlevel 5 - 20 Volts
Input impedance RCA / Cinch10 kOhms
Input impedance highlevel13 Ohms
Outputs2 x Speaker output
Output voltage RCA / Cinch-
Signal converter for digital inputBurrBrown 32 Bit DA converter
Frequency response10 Hz - 40,000 Hz
Bass boost0 - 9 dB / 40 Hz - 120 Hz
Highpass15 Hz - 4,000 Hz regelbar
Lowpass15 Hz - 4,000 Hz regelbar
Bandpass15 Hz - 4,000 Hz regelbar
Subsonic-
Phase-
Slope high- / lowpassButterworth 12 dB/Oct.
Slope subsonic / lowpass-
Signal-to-noise ratio digital input105 dB (A-weighted)
Signal-to-noise ratio analog input105 dB (A-weighted)
Distortion (THD)< 0.005 %
Damping factor> 200
Operating voltage10.5 - 16 Volts (max. 5 sec. down to 6 Volts)
Idle current2400 mA
Fuse3 x 30 A LP-Mini-fuse (APS)
Additional featuresActive, adjustable crossover, bass boost, input mode switch, highlevel input with Advanced Diagnostics Error Protection (ADEP), Auto Remote switch, SPDIF Direct In switch, cable remote control for volume adjustment
Dimensions (H x W x D)50 x 260 x 190 mm /
1.97 x 10.24 x 7.48”
222.9 KB
Görüntüleme: 19
225.5 KB
Görüntüleme: 20
162.8 KB
Görüntüleme: 19
182.3 KB
Görüntüleme: 21
188.2 KB
Görüntüleme: 22
