Bu comp.hakkinda bilgisi olan arkadaş var mı ?
- Size 17 cm
- Maximum power input 330 W
- Nominal input power 110 W
- Frequency response 30 - 96.000
- Sensitivity 85 dB
- Impedance 4 Ω
- Crossover Frequency 2000 Hz
- Mounting Depth 65 mm. Tweeter: 15 mm
- Cut-out Hole 144 mm
- Woofer material Aramid Fiber plus Cellulose Fiber Dual Layer Cone
- Voice Coil type Copper Round Wire 2-Layer
- Voice Coil bobbin type Glass Imide
- Lowest resonance frequency 57 Hz
- Tweeter size 29 mm
- Tweeter material Aluminium Hard Dome
- Magnets Woofer: Ferrite
- Tweeter: Neodymium
- Weight 1.26 kg
- High Resolution Audio
- Open & SmoothTM
- 2-Way Component
