arkadaslar elimde cadence s3w12 bass var buna spl kabin yapmak istiyorum buna ölcu verebilicek varmi aranizda aracim opel astra j sedan en boy seklinde olcu yazan olursa cok memnun olurum bas 2400w;1200rms xetec 1500.1 le besliyorum
Specifications
RMS Power Handling: 1200 Watts
PEAK Power Handling: 2400 Watts
Frequency Response: 20Hz – 500Hz
SPL @ 1w/1m: 92dB
System Impedance: DVC 4-Ohm
Magnet Weight: 49,04 oz
Structure Weight: 98,08 oz
Cutout Diameter: 11,15″ (28,32cm)
Mounting Depth: 8,4″ (21,34cm)
Features
• 3″ (7,62cm) High Power Blackened Aluminum VC Former
• Magnet Motor Heatsink with Heat Pump Cooling Technology
• Ultra Saturated High BL Magnetic Motor Gap
• Dual Spider System on Raised Suspension Ring
• Dual Nickel Plated Banana Plug Terminals Enclosure in Custom Housing
• High Densitiy, Double Laminated, Stiched, Tall Foam Surround
• Customer Molded Rubber Gasket
• Cast Aluminum Frame Basket
• Stylized Mesh Air Vents
• Ultra Stiff Woven Carbon Fiber Glass Cone
• Triple Y-35 Magnet
Specifications
SPL @ 1w/1m: 92dB
Features
