Team_Rf
5 Şub 2017
Rockfordun parametrik ekosudur. Piyasada zor bulunur. 4 band dır. Fiyat foruma özeldir.
Fiyat: 300
İletişim : 0537 853 27 97 Arayan kişi forumdan olduğunu belirtirse sevinirim
Özellikleri ;
Frequency Response 20-20kHz ±0.5dB
(EQ controls set to flat)
Signal-to-Noise Ratio 100dB (A-weighted)
Input Impedance 20kΩ
Input Sensitivity Input “A” Variable from 550mV to 8.5Vrms
Input “B” preset for 5.8V (+3dB gain)
(A/B 1.7Vrms input for 10dB headroom)
Signal Present Illumination ≥25mVrms input signal
Output Impedance 50Ω
Output Voltage Front 9.5Vrms max.
Rear 9.5Vrms max.
Subwoofer 9.5Vrms max.
EQUALIZER
Number of EQ Bands 4
EQ Center Frequencies Band 1 40Hz-80Hz (variable)
Band 2 250Hz
Band 3 1kHz
Band 4 1kHz-20kHz (hinge filter)
Boost/Cut Range Band 1 ±10dB
Band 2 ±10dB
Band 3 ±10dB
Band 4 ±0dB/+12dB
Number of Inputs 2 (A/B)
Number of Outputs 3 (Front/Rear/Subwoofer)
Volume Control Range 26dB
Subwoofer Control Range 26dB
GENERAL
Power Requirements +10V to +15.5V DC
Current Consumption <500mA
B+ Fuse Size (internal) 1/2A
Fuse Type AGC
Dimensions 1"H x 615⁄16"W x 43
⁄4"D
(2.54cm x 17.62cm x 12.06cm)
Weight 1.2 lbs. (.544kg)
