Siz olsanız Bu ıkı Bass Arasında kalsanız hangısınıo tercıh ederdınız ?
Dual olarak kullanılıcak.
Yorumlar ıcın sımdıden tesekkurler.
Machete Spec..
Model M12 v2 D2 / M12 v2 D4
Type Subwoofer
Size 12 inch
Voice coil size 2.50 inch
Cone Paper
Magnet Ferrite
Voice coil wire Copper
Surround Foam
RMS Power 500 W
MAX Power 1000 W
Frame Steel
Impedance 2+2 / 4+4 Ohm
SPL 87.40 / 87.70 dB
Fs 31.50 / 31.80 Hz
Qts 0.46 / 0.44
BL 21.50 / 22.10
Re 1.8+1.8 / 3.6+3.6
Vas 42.31 / 48.08 L
Xmax 14.00 / 14.00 mm
Mounting depth 6.14 inch
Cut-out dimension 11.08 inch
Gross weight 24.14 lb (10.95 kg)
Edge Spec..
Technical Specifications
TS Parameters
Machete Spec..
Type Subwoofer
Size 12 inch
Cone Paper
Magnet Ferrite
Surround Foam
RMS Power 500 W
MAX Power 1000 W
Frame Steel
Fs 31.50 / 31.80 Hz
Qts 0.46 / 0.44
BL 21.50 / 22.10
Vas 42.31 / 48.08 L
Edge Spec..
- EDB12D2-E7 12” Subwoofer
- Non Pressed Paper Cone
- Wide Roll Stitched Dual Foam Surround
- Dual Black PC Spiders
- Spring Loaded Connectors
- High Quality Y35 Ferrite Magnets
- 64mm 4 Layer Black Aluminium Voice Coil
- Dual 2 Ohm Impedance
- Surround Big roll foam - stitched
- Dustcap: Black PP
- Voice Coil: 36mm Copper winding
- Spider: 2pcs black PC
- Gasket: Rubber
- Top Plate: 10mm Black anodized
- T-Yoke: 10mm Flat
- Terminal / Wire: Terminal
- Impedance: Dual 2 Ohms
- RMS Power: 700 watts
- Magnet: 156mm x 80mm x 25mm 2pcs
TS Parameters
- Fs 30Hz
- BL 17.34Tm
- Vas 39.47L
- SPL 86.2dB
- Re 3.8 Ohms
- SD 0.047m/2
- Qms 5.80
- Cms 0.13mm/N
- Qes 0.53
- Mms 221.24g
- Qts 0.48
